Andrew736 Опубликовано 1 час назад Поделиться Опубликовано 1 час назад Team building in Arknights: Endfield gets a lot easier once you stop treating it like a simple “pick four strong units” problem. You'll feel the difference pretty quickly, whether you're testing a fresh roster or looking at an Arknights endfield account Buy option to start with more flexibility. A good squad usually has one clear damage carry, two characters who help set up combos or debuffs, and one support who keeps the run from falling apart. That last slot matters more than people think. A shield, a heal, or a bit of protection at the right time can save an entire rotation. Build around one real carry Your main DPS should be the unit the whole team is feeding. Endministrator, Zhuang Fangyi, and Avywenna are good examples because they don't need everything to go perfectly before they start doing work. They can keep pressure on the enemy across a longer fight. Still, they're not solo heroes. Endfield rewards setup. If your support units aren't applying the right status effects, reducing defence, or opening combo routes, your carry ends up swinging into a wall. That's why the best teams feel like a small machine. One unit starts the chain, another keeps resources moving, and the DPS cashes it in. Combo units do the dirty work Players often underrate the characters who don't show the biggest damage numbers. That's a mistake. Electric status, Physical Vulnerability, stagger support, SP help, and clean debuff timing can add more value than another greedy attacker. A Zhuang Fangyi team, for example, can run very well with Perlica for energy and buffs, Arclight for SP flow, then Gilberta or Antal for extra team value. Nobody is just sitting there. Everyone has a job, and the rotation feels much less clunky when those jobs line up. Safer teams still win fights If you don't want every boss pull to feel like a speedrun, a steadier Physical setup can be a better choice. Endministrator with Chen Qianyu, Ember, and Pogranichnik gives you damage, vulnerability, shielding, healing, and conversion support in one package. It's not flashy every second, but it's comfortable. Electric teams have their own rhythm too. Avywenna with Akekuri, Perlica, and either Gilberta or Antal can keep enemies under pressure while building toward stronger combo windows. Cryo also has room to breathe, with Last Right backed by Sahi, Snowshine, and Fluorite for players who enjoy a more focused elemental plan. SP management is where teams break The shared SP pool is the thing that catches people out. You can't just press every skill because it's available. If low-impact casts eat too much SP, your DPS misses the moment that actually matters. A cleaner pattern is usually better: buff first, apply the debuff, trigger the first combo, follow with the next one, then let your main carry spend big. As a professional platform for game currency, items, and account services, U4GM is convenient for players who want a smoother start, and you can choose u4gm Arknights endfield account Buy when you want more room to test teams without grinding from scratch. The strongest squads aren't just stacked with rare names; they're the ones that spend SP well, trigger combos on time, and keep damage moving. Ссылка на комментарий
