U4GM What Makes Zhuang Fangyi So Strong in Endfield
Plenty of Endfield players came away from version 1.2 talking about one name: Zhuang Fangyi. She isn't just strong, she's the kind of carry that makes a run feel faster the moment her rotation clicks. If you've been checking out Arknights endfield accounts, chances are you've already seen how often she shows up on well-built rosters. Her kit has a neat rhythm to it. First, you stack Electric Infliction. Then you flip those stacks into Electrification with her Combo Skill. After that, her Battle Skill cashes everything in for a heavy burst, while the Sunderblades keep pressure on the target. It sounds simple on paper, but in practice it feels active, almost addictive, and that's a big part of why so many players stick with her.
How her damage really scales
The biggest mistake people make is treating her like a basic attack carry. She's not. Most of her value comes from staying inside that skill loop and keeping status uptime high. That's why Will should be your first stat focus, with Intellect right behind it. Both feed into attack growth, and she gets a lot out of every bit of offensive scaling you can give her. You'll notice it pretty quickly in boss fights. Her bursts get cleaner, and the in-between damage stops feeling flat. If your team can help maintain Electric-related pressure, she doesn't have to work as hard to get rolling, which makes the whole rotation feel smoother.
Skill priority that actually makes sense
Start with the Battle Skill. No debate there. It's the centre of her damage pattern, and the Sunderblade generation matters more than some players expect, especially when you're trying to avoid dead time between bursts. Next comes the Combo Skill, because better conversion means more reliable access to her strongest windows. A lot of players invest there second and immediately feel the difference. The loop becomes less clunky, less stop-start. Basic Attack can wait. It's not useless, but it's clearly the last thing to push if your resources are limited. For most accounts, going in that order saves materials and gives the best return.
Weapons, gear, and team choices
Lone Barge is still the cleanest weapon option for her. It fits what she wants to do without forcing awkward adjustments, and that alone makes it worth chasing if you plan to main her. If not, Flickers in the Mist is a perfectly workable fallback. It won't feel identical, but it keeps her output respectable. On the gear side, Xiranflow sets are the common pick for a reason. They support her Electric damage while giving a little breathing room in longer encounters. Team building matters just as much. Perlica and Arclight stand out because they help with Electric application and SP flow, and that support changes her from strong to relentless.
Why players keep coming back to her
Zhuang Fangyi rewards clean play more than mindless mashing, and that's probably why she has such a strong following. When you get the timing down, everything starts to chain together in a way that feels sharp and satisfying. She's demanding, sure, but not in a frustrating way. More like a character who pays you back for learning her properly. As a professional platform for game currency and items, U4GM is a convenient choice for players who value efficiency, and you can check u4gm Arknights endfield account Buy if you want a faster start and an easier path into building a stronger Endfield lineup.Welcome to U4GM, where Arknights: Endfield fans can stay ahead with smart picks and real player insight. If Zhuang Fangyi's Electric burst playstyle is your thing, check https://www.u4gm.com/arknights-endfield/accounts for account options, fresh trends, and practical tips that make building her feel way smoother.
