can someone please help me with configuration
robofrog configured the gu for me all working rear camera and other functions except
jukebox which is enabled in sw options
also vehicle configuration on gu smeg does not change the settings on the machine
the alert log displays faults on the machine ok
and navigation on the matrix
i looked at another c5 with smeg installed and vehicle config changed things like parking sensor on off
drl on off adaptive lighting on off
but my smeg doesnt
my smeg is from ds3
PLEASE SOMEONE HELP
Thank you
Как оказалось, файлы конфигурации имеют разные настройки для прошивки 6.1.xx и 6.3.хх
В 6.3.xx появился пункт option_vhl , который выводит силуэт и картинки автомобиля в настройках, не зная нужного параметра, силуэта нету.
Может кто подскажет данный параметр именно для Ситроен С5 ?
И превратилась в лисицу!
i am using that smeg with 6.3 xx
but if you change settings on the car steering wheel they go on and off like lighting mpg kml on matrix but  on smeg when you change settings on the smeg they dont change on the car they go off on smeg but when you press ok they back the \ same again
the other thing is i have jukebox enabled which does not require a cd player yet it is not showing in source list
i took the sdhc card out and put in computer and it has jbx partition in it
this is all i need to resolve as everything else is fine even faults on the car or low fuel level show up when you press the check button on the smeg
really want to get this finished now
  • 5 месяцев спустя...
